Connecting to Zwift
Pair Your Cadence Sensor
Trying to maximize workout results? You’re going to need a cadence sensor. It’s a critical piece of data for most Zwift workouts because it helps you pinpoint where you’re most efficient. Whether you have a Wahoo, Garmin, or another device, following these steps will have you set up and ready to go in no time.
  1. Log on to Zwift.
  2. Start pedaling to wake up the sensors.
    Click “Search,” underneath Cadence on the Pairing Screen.
    Select your device when it appears
    If it doesn’t appear, slowly pedal until it shows up, then choose it.
  3. Click “Okay.”
  4. You’re set up and ready to go.
