Want to run on Zwift? Just grab a Zwift RunPod and you’ll be off and Zwifting in no time. Follow these instructions to learn how to calibrate your RunPod.
- Connect your RunPod to Zwift. Just go to the pairing screen to do this.
- Find the calibration button on the pairing screen. It’s the button with the wrench on it.
- Push the calibration button.
- Zwift will bring you to the Calibrate Device screen. Use the Up and Down arrows to select a speed you can comfortably run at
for a few minutes. - Select Next and follow the on-screen prompts.
- Set the treadmill to the running speed you selected.
- Run at that speed for 40 seconds. Do not stop your treadmill.
- You'll be prompted to set your treadmill to a second speed.
- You'll be prompted to set your treadmill to a third speed.
- When the "Calibration Complete" message appears, select OK.
- If you run into an issue, restart the calibration process.
- When the Paired Devices screen loads again, select OK.
- Good job. You calibrated your RunPod. It’s time to get out there and knock out a few miles.
