Zwift Ride with KICKR CORE, the all-in-one smart bike. Only £1,199.99
ZWIFT:RIDE
The smart bike from Zwift—it’s your complete indoor cycling setup.
All-In-One
Zwift Ride has everything you need to start riding and is quickly adjustable for multiple riders.
Unlock All of Zwift
Real ride feel, smooth virtual shifting, and full control from your handlebars—it’s the best way to Zwift.
Sleek, Stylish, Silent
Zwift Ride is designed for the home. It offers a space-saving, quiet setup that's smaller than an outdoor bike.
”The Ride is a No-Brainer.”
- Cycling Weekly
YouTube video placeholder
Zwift Ride with Wahoo Kickr Core Zwift One
Zwift Ride with Kickr Core
All-in-one. Ready to go.
Zwift Ride Frame
Zwift Ride Smart Frame
The ultimate upgrade for your Zwift Ready or Zwift Cog Compatible smart trainer.
Effortless Control
Control all of Zwift from your handlebars. Steer, use PowerUps, give a Ride On, and more.
Virtual Shifting
Get ready for quiet, quick, and customizable virtual gear changes at your fingertips.
Smart Frame
Transform your Zwift Ready or Zwift Cog Compatible smart trainer into an always-ready, all-in-one smart bike with Zwift Ride Smart Frame.
FAQ
All Zwift Ready smart trainers are compatible with the Zwift Ride Smart Frame. Check our our article for info on Zwift Ready compatibility.
The total length of Zwift Ride with KICKR CORE is 1.36 m, and the total width is 0.43 m. We recommend you have a space at least 47" (1.20 m) wide and no less than 60" (1.5 m) long to allow for your equipment, as well as room for you to get on and off.
Everything you need to set up your Zwift Ride comes in the box, including a Quick Start Guide and Zwift Key, the only tool needed for setup and any adjustments you will need. All you’ll need to add is the device you’re using to Zwift.
Zwift Ride is recommended for users within the following range:
  • Rider height min:5' (152 cm)
  • Rider height max:6' 6" (198 cm)
  • Rider weight max: 265 lbs (120 kg)
Jump on Zwift Ride
Ready to get started on Zwift? Buy Zwift Ride now.
“This superbly made and affordable all-in-one solution certainly is the best Zwift accessory out there.”
– T3
“The trainer massively undercuts the smart bike market in price and does so with a high performing, and incredibly fun and practical setup.”
– Cyclist
“The defacto smart bike recommendation for almost all riders”
– DC Rainmaker
